Point List / Report
  • 1.  Point List / Report
    Posted 09-17-2020 22:52
      |   view attached
    Hi
    I have a lot of points in a project and I want to make a list of them and a report, but only part of them. I would like to select them by code or a layer that they are in. Is it possible?
    Is there any video about editing/working with reports? It is quite complicated for me to get throught.
    I created a report but now I cant edit it. All windows for editing doesnt allow me to get in (added video).
  • 2.  Re: Point List / Report
    Posted 09-18-2020 08:21
    The TBC Point List Report only reports to PDF or Word format. You can use Custom Reports to customize the output to a word template that you define yourself (Needs Word not Office 365 version of word).
    If you open the Points Spreadsheet and then select all of the rows using SHIFT and select the top and bottom rows, you can then Copy the contents to the clipboard and then paste it into Excel and then use Excel to structure the report as you need it.
    We have a Point List report in the RPS Command Library that generates a CSV / Excel File of Point Data and you can reference those to a Surface and or an Alignment to get Station and Offset as well as Delta Z to a target surface. Once it is opened in Excel then you can sort and filter using Excel Rules to get what you need and you can format the report as you want it.
    That is something you can try out if you want a 7 day trial of the command library - email me if you want to test that out.
    alan.sharp@rockpilesolutions.com
