ok...so I need $295/year to devide a line into parts that is not equal?....
and I need to build templates for abbility to offset a line/lines both directions in one step? .. (i havent find the sideslope command)
its a pitty... there is a local geo-software here that is not in that hight level as TBC is at all and it can do it just by clicking the checkbox
Can the "both-sides-offset" feature added into TBC into offset menu, couse it seems to me as simplier way of use than another command or making templates?
As well as I would appreciate setting of color for styles in draughting (text, line, arrows for dimensions and so on).
Next useful thing would be preview concurrently with changing setting the styles and so on and applying after pushing the OK button. I worked with Abdobe Indesign (typhographic software) and there you can see you changings while you are setting a style and it is just a preview.
It is not comfortable to open the manager, change setting, press ok again a again till find the suitable size, font and so on.
