Lost values after importing dwg
  • 1.  Lost values after importing dwg
    Posted 08-10-2020 05:14
    Hi
    i have this dwg. First problem is that all values for dimensions turn to value "0.000" after importing (drag and drop or trought import menu). The problem is not in other cad programs.
    Next issue is that I cant delete any layer. I can delete the contents but there is protection all the time. I tried clean up as many time as there was a report with any cleanup-changes.
    Ive read about a button to isolate a layer of selection. I havent found it. Is there any possibility to highlight the layer of selection?
    Thank you
    Attachment(s)
  • 2.  Re: Lost values after importing dwg
    Posted 08-10-2020 06:07
    When i viewed the DWG in a viewer, the dim text appear.  When I import ( i do not drag and drop, instead i choose the import folder.  That way you can choose the correct Unit.  TBC show dim as zero on my end also.  I looked at the properties and changed the " edit text and Independent text " to say NO.  this made the dim text appear as the correct dim.  The only thing is the dim shows up as Meters.  In my DWG viewer it shows up as US Survey foot.  if the file is in Meters. You would have to click import and change the Unit to Meter.
  • 3.  Re: Lost values after importing dwg
    Posted 08-10-2020 11:37
    In the View Filter Manager, at the top of the dialog there are a few button icons. The Isolate function is one of those buttons (near the middle)
    You can select the button - it is sticky - once enabled you can select any layer in the layer list of the View Filter manager and that layer will be isolated on screen. You can use the Up and Down arrow keys to scroll through the list and that will isolate each layer in turn as it is selected.
    If you first click on an object on screen on the layer that you wish to isolate (one object only) then tap the Isolate button it will isolate the layer of the selected object for you.
    If you click the Zoom Extents button which is to the left of the isolate button as well, then as you isolate a layer it will zoom extents to that layers limits which can be helpful when reviewing imported data on different layers..
    Deleting Layers
    In AutoCAD or Microstation or other CAD products, a Block Definition is placed on a layer but can contain data that is on other layers. When the data is stored as a Block in the DWG / or TBC Project, we display the Block and its contents like AutoCAD or Microstation as being on the layer where it is defined. However the linework of the block can be on many layers and if you those layers they display as empty until you explode the block, at which point all the lines of the block now can be found on their original layers.
    Also in AutoCAD they have Model Space (TBC Plan View) and they have Paper Space (TBC Sheet View). While there may be no data on layers in the Plan View, you may also find a Sheet View has been created (look for plan sets in the project explorer) and you will likely find data that is on layers but only visible in TBC Sheet View. In that case we do not let you delete the empty layers in Plan View because there is actually data in the Sheet View on those layers.
    So sometimes to Delete the Empty Layers you need to
    1) Layers look empty but cannot be deleted (TBC stops you from deleting layers that are needed), for Blocks or for Sheet View (the two most common scenarios - there are other reasons to do with Selection Sets and how they may have been assigned to View Filters in TBC that stops you seeing something, or you have turned off a Visibility Flag in the Advanced View Filter Settings, or in Display Properties you have elected to not display objects that are 2D only etc.
    2) When you explode a Block, you still need to check to see if there are any blocks that remain, as it is not uncommon to have blocks nested inside of blocks - you often need to explode several times before you get to the point where no blocks remain.
    3) If the project has "unused blocks" then they can also have an affect on deleting layers - there is a Purge Blocks command as well as the Project Cleanup command that can help you here - typically an unused block is one where there is an instance saved in the project but not used in the project - the Project Cleanup command can delete Unused Blocks, but if one remains for any reason you can use Purge Blocks to eliminate any ones that are not being used in the project - but again be aware of Nested Blocks - that can stop something from being purged or deleted if it is not used natively but is being used embedded in another block of the DWG file.
    Dimension Issue
    Frank is correct - on import of the DWG file (and I will get someone to look at this), you should select all the data in the project, then in the Properties pane - there is a pull down at the top of the pane that allows you to see the object types that have been selected - select CAD Linear Dimensions (that then shows the properties for that type of object) and set the "Edit Text" property to No and the "Independent Text" property to Yes - note that these are dependent on each other so first set Independent Text to Yes and then you can set the Edit Text to No. This will then display the Dimensions - I am not sure why the text size changes in that process - but at least you will have the Dimensions.
  • 4.  Re: Lost values after importing dwg
    Posted 08-11-2020 23:16
    Thank you Alan and Frank...
    I have tried the button fo isolation and its good to know that.
    Dimension Issue
    I cant see where is the place to select "all the data in the project","the properties" for "Edit Text" and "Independent Text"  in the import panel
    Can you help me to get there?
    The default settings for this issues should prevent that, shouldnt it? Becouse I could not have noticed it. Can I set it for all dwg?
    Frank...   How I can get to the properties in the pictures? I can hardly notice/read it is properties. I suppose it is the same "properties" Alan wrote about, isnt it?
  • 5.  Re: Lost values after importing dwg
    Posted 08-12-2020 10:49
    Click on the image to enlarge. It will be the image large and clear.
    right click on item to get pop up window > click properties to change the "independent text and edit text"
    you will have to manually change the settings at each dim.  Quick way to do all at one time is > right click > select similar > right click while all the line dim are highlighted > click properties.  This will allow to modify all dim at the same time instead of one by one.
  • 6.  Re: Lost values after importing dwg
    Posted 08-12-2020 11:55
    Here is a video of the process
