TBC Custom Export errors
  • 1.  TBC Custom Export errors
    Posted 02-24-2017 07:03
      |   view attached
    I am attempting to use the new custom report to a word doc function in TBC.  When I run the tutorial I get an error. (uploaded in the attached pic).  We have an Advanced TBC license and are running v3.81.
    Any reason for these errors?
  • 2.  Re: TBC Custom Export errors
    Posted 02-24-2017 16:09
    Hey Ross,
    During which part of the tutorial does this error message appear?  When you attempt to generate the report from TBC?
    Cheers,
    Riley Smith
  • 3.  Re: TBC Custom Export errors
    Posted 02-27-2017 05:49
    Riley,
      The error occurs when you select "Edit Layout" and it attempts to open the report layout file.
  • 4.  Re: TBC Custom Export errors
    Posted 03-05-2017 19:51
    Can you provide the data set you are using when this error occurs?  This is hard to troubleshoot without it.
    Cheers,
    Riley
  • 5.  Re: TBC Custom Export errors
    Posted 03-06-2017 11:58
    I am using the sample dataset provided in the tutorial.  Is this a case of using MS office 2013 and not 2010?
  • 6.  Re: TBC Custom Export errors
    Posted 03-06-2017 14:35
    The customized reporting feature works with versions of MS Word 2010 and newer.  Another option is to clean out the temporary folder on your C Drive.  You can do this by:
    • Right click on your Windows (C:) folder and select Properties
    • Select Disk Cleanup button
    • Check the box next to the Temporary Files and hit Ok
    • Restart computer
    Let me know if this works for you or not.
    Cheers,
    Riley
