Is there a way to fix the graphics so my arc and circles don't look corded? If I zoom way in the will look right when I zoom back out the go corded again.
  • 1.  Is there a way to fix the graphics so my arc and circles don't look corded? If I zoom way in the will look right when I zoom back out the go corded again.
    Posted 08-13-2019 13:31
  • 2.  Re: Is there a way to fix the graphics so my arc and circles don't look corded? If I zoom way in the will look right when I zoom back out the go corded again.
    Posted 08-14-2019 13:24
    Glenn
    I had noticed this also in TBC v5.1 and I can tell you that the Regen that turns Chords to Arcs will happen earlier in the zoom process in the next release - I use that daily and have just compared the two and it is doing better in the next update.
    I don't believe that there is anything that you can do in the software to change this unfortunately - the development team are working on Graphics optimization and what you are seeing was a side effect (we utilize a graphics Engine called Hoops (used also by Autodesk in AutoCAD etc.) and that had a defect that made us have to roll back the Graphics Driver Version and what you are seeing was a consequence of that unfortunately
