tbc
  • 1.  tbc
    Posted 04-03-2020 13:04
    Hi
    I have version 3.40 TBC.
    My question is.
    J, export my klm polygon with the numbers at each vertex in google earth
    numbers are not displayed
    possible to send me a solution
    Best regard.
    yvon Laurin
  • 2.  Re: tbc
    Posted 04-04-2020 13:30
    Do you mean Point Numbers - if yes then I would use label points to label the points with text and that can go to Google Earth. Point numbers are not real objects so they dont get exported.
    We added text support to Google Earth export fairly recently so not sure that it will work with the version you are using - if you post the file I can maybe export a KML / KMZ for you from a more recent version to show you what is possible
  • 3.  Re: tbc
    Posted 04-04-2020 15:15
      |   view attached
    Hi Alan
    Thank you for your good collaboration
    I send you the drawing in DWG geodetic nad 83
    canada
    Best regard
    yvon
    Attachment(s)
    dwg
    klm test.dwg   14.04 MB 1 version
