Import SX10 point cloud after .job import?
  • 1.  Import SX10 point cloud after .job import?
    Posted 11-13-2018 12:41
    I have a .job that was imported and the traverse was adjusted. However, the folder containing the .rcwx was not in the directory so it was not imported. Is there a way to import it post traverse adjustment or do I have to start over?
  • 2.  Re: Import SX10 point cloud after .job import?
    Posted 11-17-2018 07:38
    I believe you can just re-import the job. TBC should recognize that the .job file was previously imported. It will give you three options on how to proceed. You would want the option of “Preserve office edits”.
  • 3.  Re: Import SX10 point cloud after .job import?
    Posted 11-19-2018 10:40
    Spot on, Thanks!
