Superelevation instructions
  • 1.  Superelevation instructions
    Posted 11-24-2019 22:52
    I am having a hard time understating how TBC is executing superelevation instructions in corridor modelling.
    I have created a dummy corridor with multiple material layers. Typical XFall -3%, max superelevation 6%. All material layers 250mm deep, defined at +/- 5m offset with -3% slope. Typical section on the straight is a simple crown.
    When all nodes are on top of each other, I am getting exactly the results I was expecting when superelevated. Please see screenshot below:
    Screenshot 1. Max superelevation of 6% applied with no dramas.
    But when I move one of the nodes left or right, it all falls apart:
    Screenshot 2. Max superelevation of 20.91% instead of 6%
    I have marked up in red the only difference between both templates.
    Below is the video showing how drastically changes the execution of that template.
    I know how to fix it (superelevate only Finished layer and define Material Layers as delta OS/delta elevation), I just want to know why its happening...
    Regards,
    Marian
  • 2.  Re: Superelevation instructions
    Posted 01-08-2020 22:22
    Has anyone else experienced strange behaviour as described above?
  • 3.  Re: Superelevation instructions
    Posted 02-23-2020 16:47
    up..
