How to create isopachs at intersection of two surfaces?
I need to create a line string that represents cut/fill line and additional strings at a specified interval that represent height difference between two surfaces.
Something that provides output like GC25 and SHADEISO in Terramodel.
I tried to create cut fill map between two surfaces and display cut/fill line, but CF line cannot be exploded and later draped onto target surface.
Also, in the simplified example where one of the surfaces is a plane, I tried to manually snap to surface-plane intersection in Cutting Plane View but snaps seems not to work in that View.
Regards,
Marian
