A profile can only exist with an alignment. Anything else you draw in
Profile View is not linked to the alignment only the Profile View of the
alignment. If you actually create a Vertical Alignment and draw the "pline"
as the profile (as a profile) then if you change the Active Vertical
Alignment it will be what elevates the alignment in eg 3D view, but each
one that you draw will sit on the alignment location in Plan so you will
not see any change, only in 3D view. There is no other connection available
- but I can see what you are asking - if you drew in the profile view, you
want the Station to be converted to XY and then use the Pline Z to draw a
3D line along the alignment that matches the alignments position - correct?
On Mon, Jun 15, 2020 at 6:12 PM marian.plucinski@seymourwhyte.com.au <
