I have run into some dramas with CF Maps for Projected Surfaces.
I have seen that exercise as tutorial. I have also managed to do do it myself on the previous version of TBC (5.21).
CF Map created between two Projected surfaces shows correct:
- daylight line
- cut/fill values
- volumes
It displays completely incorrect visualisation (shading) of the cut fill map.
Does anyone know why it might be?
1) Scanned wall
2) Sampled @ 10mm grid
3) Projected Surface created using Sampled Point Cloud
4) Cut Fill Map created using Two Projected Surfaces: One from Point Cloud and Second one as just a random plane (both projected onto same Plane).
5) Properties of the CF Map
6) CF Map itself
