I'd like to export multiple polygons from TBC, in SHP or KML format, to be used in MS Excel / 3D Maps.
When I create my regions in Terramodel (closed PLINE) and export to KML, I can read that file in 3D Maps.
When I create my regions in TBC I encounter some problems:
-regions created as Boundaries do not import (those are exported as Lines.shp file)
-regions created as Linestrings do not import (those are exported as Lines.shp file)
-regions created as Polygons do import (those are exported as Polygons.shp)
My questions are:
1) How to force TBC to export Boundaries to SHAPE file as Polygons?
2) Alternatively, how to convert many Boundaries to Polygons while retaining their names?
To clarify the terms I used:
By "Boundaries" I mean regions created with "Create Boundary" command
By "Linestrings" I mean regions created with "Create Linestring" command, with Auto-Close ticked on
By "Polygons" I mean regions created with "Create Polygon" command
Failed import in MS Excel / 3D Maps (Exported from TBC):
![](https://community.trimble.com/servlet/JiveServlet/downloadImage/2-26221-149749/pastedImage_4.png)
