Slope Arrow Colors
  • 1.  Slope Arrow Colors
    Posted 08-28-2020 06:37
      |   view attached
    Has there been a way added to change the slope arrow colors?
    On a couple of my projects, I can barely see them in that light green color.
  • 2.  Re: Slope Arrow Colors
    Posted 08-28-2020 07:06
    I don't think there is a way to change the color. You can change the size in the project settings but there is no option for color that I know of. If you increase the transparency of your surface under properties you can make them easier to see.
  • 3.  Re: Slope Arrow Colors
    Posted 08-28-2020 07:12
    Yea,
    I see where to change the size.
    I am overlaying the arrows on a drone image and do not want to dim it.
    Thanks for your response!
  • 4.  RE: Re: Slope Arrow Colors
    Posted 09-07-2023 14:01
    Hi Nick,
    I have extremely tiny arrows.  Where in settings can I make the arrows larger?
    Thank you,
    Beth Safranski
  • 5.  RE: Re: Slope Arrow Colors
    Posted 09-08-2023 12:39
    Edited by Erik Petersen 09-08-2023 12:39
    @Beth Safranski, Its under Project Settings>Computations>Surface. 2nd one down on the list
    Erik Petersen
  • 6.  Re: Slope Arrow Colors
    Posted 08-30-2020 05:55
    Woody
    The only things that I can suggest are the following - depending on what you are trying to achieve here
    1) The color of the slope arrows is hard coded to that lime green color - you cannot change it. However when you click on the surface to select it, you can change the Highlight Color and Highlight Lineweight in support options - eg change to Mid Grey and Lineweight 1 for example so when you select the surface - the Surface Triangles and Slope arrows change color to the ones that you selected - that way they will display in a different color at least temporarily as an overlay when the surface is selected
    2) You can turn off surface shading in the surface properties so that you only get the triangles and the slope arrows for example
    3) In the 3D View - if you use 3D View Settings you can turn on Enable Sun Lighting and then play with the Date, Time and Brightness settings - these allow you to change how the surface is illuminated and if you do a Top View that has some effect on the visual result
    4) Changing a white background to a black background also has some effect when you apply some degree of transparency to the Surface or Image as the Black or white background will either Darken or lighten the surface or image as it is able to shine through the transparency
    In the above image I have a Georeferenced Image with 0% transparency, I have my highlight line weight set to 2 and highlight color set to Black and I am using a White background with a slope Arrow length of 4 and for display purposes this seems to work OK. If I want to have this showing like this - all I have to do is select the surface - however if I am trying to create output deliverables this will not work a it is only a selection display method - but it may help.
  • 7.  RE: Slope Arrow Colors
    Posted 02-19-2021 11:41
    Edited by NICK LAPENSEE 02-23-2021 05:42
    Update:
    I'm not sure when it changed, but in v5.40 the ability to change slope arrow color is in the surface properties panel.  Good job Trimble for adding the option!
    NICK LAPENSEE
  • 8.  RE: Slope Arrow Colors
    Posted 02-21-2021 10:31
    Wow, not sure how I haven't seen that option yet, I've built a lot of models in 5.40 so far.
    Awesome feature!! So glad they added that option.
    Adam Bower
  • 9.  RE: Slope Arrow Colors
    Posted 02-21-2021 22:38
    Great update!
    And another undocumented change to the TBC!
    Marian Plucinski
