Extract 1 second position
  • 1.  Extract 1 second position
    Posted 06-20-2019 01:48
    HI, just want to ask, is there any ways to get the x and y for every second of GPS observation. I already observed one station using trimble R10, use fast static and 8 minute observation and store the data every 1 second.
    how I can extract the data and get the x and y for every second?
  • 2.  Re: Extract 1 second position
    Posted 06-25-2019 14:51
    Hi Hulwan, is there a specific application that requires positions at each epoch? And how do you use those XY values later? I only know a way to explode a node in a baseline session into epochs, but not sure how to do it when you only have one point surveyed.
  • 3.  Re: Extract 1 second position
    Posted 06-30-2019 23:15
    Hi Rui Wu,
    Actually is just to see how the distribution of the point every epoch.
    yup, some people say need to have a baseline then can export the data every epoch, if just single point,
    I am also still looking the ways how to extract the x y and z.
  • 4.  Re: Extract 1 second position
    Posted 06-26-2019 03:26
    Hi Hulwan
    When you import data, you can choose force kinematic.
    PPK can get the coordinates of each point.
    Hope to be useful~
  • 5.  Re: Extract 1 second position
    Posted 06-28-2019 08:27
    Hi Junning, would you post your steps as well? I just tried forcing kinematic on a T02 file but it didn't give me any coordinates, only a continuous segment. Did I miss something? Thank you.
  • 6.  Re: Extract 1 second position
    Posted 07-03-2019 02:32
    Hi Rui Wu,
    Sorry for the mistake. The operations I talked about need base data.
    Just one observation data can only see the approximate coordinates, and I don't know how to see the coordinates of each epoch.
    @HULWAN AFIF  Sorry, I was wrong.
  • 7.  Re: Extract 1 second position
    Posted 06-30-2019 23:17
    Hi Junning Wang
    PPK (Post Processing Kinematic) means still need a base to extract the data every epoch right??
    let say we use rinex observation data, is there any ways we can extract the data every second?
  • 8.  Re: Extract 1 second position
    Posted 07-04-2019 08:23
    Hi Hulwan,
    You need to chose "force kinematic" at import of the rover data into TBC, then you can proces each epoch..
