I've got a Plan Form I've been using in Terramodel - can I import this into TBC as a Drafting Template ?
Either "natively" or by DXF?
You can import it and then use copy to sheet to move it to a Planset and then scale etc to make it as you need it and then write it out as a VCL planset etc. I did a post in the Drafting blog a while back on how to convert an Autocad dwt file which would be similar. You will need to reset smart text etc but for sure you can do logos as images will need to be imported separately and placed etc.
Thanks Alan,
I had imported it as a DXF into Sheet View and then changed scale / text,
Cheers,
John
