Point Selection by Inside CAD Linestring
  • 1.  Point Selection by Inside CAD Linestring
    Posted 06-18-2019 14:52
    Is there a way to select points inside a CAD Linestring (like the Terramodel command "Inside") ?
    I have multiple Sections of a Twin Tunnel that I want to Assign Chainage Values to Points but they vary slightly in/out of Chainage ranges and I have to remove lots extraneous points manually if I increase the range
  • 2.  Re: Point Selection by Inside CAD Linestring
    Posted 06-18-2019 15:18
    would polygon select not be what you are after?
  • 3.  Re: Point Selection by Inside CAD Linestring
    Posted 06-18-2019 15:46
      |   view attached
    I was trying to avoid that – I’ve already got linestring boxes around points so would be easier just to use them
    Regards,
    John Mill
    1 Cathro Road, Wanganui, NZ 4501
    Ph 021 523 872
  • 4.  Re: Point Selection by Inside CAD Linestring
    Posted 06-19-2019 03:24
    Hi John,
    if you have BC 5 with macro support (survey advanced edition) you can use the macro "pointcloud by boundary".
    You have to be in polygon select mode and then click on the appropriate (closed) line string. It selects everything within, lines, arcs and so on. Not just point cloud points.
    Cheers
    Ronny
  • 5.  Re: Point Selection by Inside CAD Linestring
    Posted 06-19-2019 12:52
    Awesome Ronny,
    That exactly what I needed!
    Cheers
    John
  • 6.  Re: Point Selection by Inside CAD Linestring
    Posted 12-12-2019 08:40
    I just stepped into the same boat.  I need to select line thou not points inside a closed line.   I had to explode a surface so I can do some elevation changes.
    Select by polygon work great.
