Coordinate Transformation of VCL Files
  • 1.  Coordinate Transformation of VCL Files
    Posted 06-23-2019 22:13
    I have numerous TBC jobs generally by daily Surveys (over the last 3 years) from which I've extracted VCL Project Link as I want to retain Photographs with their associated As Builts,
    I've then imported these Job Link files into a "Combined Job" for a compilation to produce an As Built set of data (both Plan and electronic),
    The Client requires the Data Sets in two seperate Coordinate Systems (the Design Set and basically a GIS Set for the Local Council) - NZ Mt Eden Datum 2000 and NZTM Datum 2000 directly linked.
    If I change Coordinate Systems in project explorer the imported Objects/points won't transform (but an imported csv file will)
    Error meesaage "Some Points could not be computed due to transformation errors. Check your actual coordinate system settings"
    I have gone back to the "source" TBC jobs and I can Transform the data OK in those.
    As a seperate issue also DXF/DWG CAD Files imported won't transform either - they're underlying Cadastral Data sets
    Any suggestions please?
