FXL will not open
  • 1.  FXL will not open
    Posted 03-25-2020 17:22
    I have Feature Definition Manager installed and I would like to edit an existing FXL file, although when i try to open the FXL in Feature Definition Manager I get the following error and it will not open. "The file format is not valid or the file cannot be read."
  • 2.  Re: FXL will not open
    Posted 03-29-2020 13:52
    Can you share the file- there is version dependence in FXL files so if you saved it in a recent version of TBC it may not open in an older version of TBC - I can take a look if you share the fille
  • 3.  Re: FXL will not open
    Posted 03-31-2020 08:11
    I have had FXL files saved in 9.0 version and would not open. I went back and did a save as for 8.0 version to be able to open in TBC.
