Of course we can do benches!
Create a new project using the Utility meters project template. Go to the template editor, select the last template in the list and then go to the side slopes tab. This example has just one bench but you can do as many an you need. The template works on conditional statements so depending on the depth at the last point you can tie to ground or make another bench.
In this example if the depth of the current point is >.1m then it creates a point 1m over. Then if the depth is <1m it ties vertical. If the point is >1m then it goes up 1m to create a point. After that it ties to ground at a slope. If you want to add more benches you can delete the last tie and repeat these three steps up to as deep as you need to go.
tim
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/143239.png)
