Unfortunately I cannot I am under NDA. Basically I need to overex under several buildings on the same site. I need to go down to the bottom of a peat layer which is as deep as 20 feet in some areas. I need to backfill up to a deep foundation and then again to finished grade. Overexcavation and site improvement modules would not catch a huge quantity of material if I can only take a vertical footprint. If I take the average depth and offset my excavation limits as my site improvement limits, I am not realizing the full depth I need to go to for the bottom of the peat strata layer I have modeled.
It would seem that the program has the capability to create surface tie's (which work great for finding the contours of the excavation) and it has the ability to drape site improvements and overexcavation to surfaces. Why not incorporate the surface tie as a slope function within the takeoff portion of the program. Another issue with the surface tie is that the daylight line cannot be used as a surface boundary. So even after I have found the new extent of my dig, I cannot easily and quickly constrain my new surface to this extent.
In order to get around these issues, I am currently having to create a separate surface for every dig spot, for each surface I am digging through, and having to tie to my existing ground for excavation quantities, and again to the finished design for backfill quantities. Then run a separate surface to surface report for each one.
Although site improvements are great, the typical section of a building is never vertical. Although surface tie provides the function, it does not help me with my takeoff quantities as integrated currently.
