Setting up a job with Access
  • 1.  Setting up a job with Access
    Posted 04-12-2020 09:48
    I am struggling with the simplest way to create a new job within Access so that it is on State Plane Coordinates and has a record map Basis of Bearings.
    The area I am working in has no reliable NGS benchmarks, so I need to do an OPUS solution on a point and I have recovered several monuments of record.  I would like to be able to set up the base station on the point to record the OPUS data, measure the found monuments, rotate them to a Basis of Bearings so that I can produce search coordinates for the recovery of other monuments and conduct a topographic survey of the property.  Ideally, I would like to do this all in one shot.  Then be able to take the data back to the office and post process.
    Does anyone have a good workflow solution to this process?  I am relatively new to the Trimble software.
    Software:  Access 2017.23 and TBC 5.20.
  • 2.  Re: Setting up a job with Access
    Posted 04-13-2020 06:54
    Guy
    Can you please post this question on the Geospatial Community Forum as we do not handle Access questions on this CEC forum as that is not a part of the CEC portfolio of products.
    https://community.trimble.com/welcome
    Thanks
  • 3.  Re: Setting up a job with Access
    Posted 04-13-2020 07:55
    Will do.
    Thank you for letting me know
