See if this does what you want:
Create a contour at elevation 1.5
Explode the contour
Add the contour as a member of the surface
Erase the lines above the contour
If this is not what you want, please add some more explanation and attach your data.
Depending on how you calculated the original daylight line, you might be able to just intersect a surface with the desired elevation.
Tim
