When doing things like offsetting linework or creating contours, if I'm in "my filter" instead of "all" in the "view filter manager"I can't view the offsets or contours I'm creating, and in the layer selection menu of the "offset line" window, there's a little yellow dot that says "this layer not visible in any graphic view"
The "all" filter in the "view filter manager" is locked, and the things I create only show up in that filter. Did I check or uncheck a box somewhere I shouldn't have?
here are screenshots of my filter vs the all filter and the little yellow dot with note.
Thanks
NB
