Download and install the Explode Surface TML from the Macros forum - that does what you want to do already Ben - I am not sure but it may even be installed with 5.10 - if yes it will be on the Macros Ribbon or you will find it as one of the _XXXX commands in the Command Pane
Macros Forum Link: Click here
