Siteworks Crashing
  • 1.  Siteworks Crashing
    Posted 08-07-2019 12:03
    I have been dealing with Siteworks crashing for what seems to be no reason.  The nearest I can tell is if you start moving around to fast in it.  It will crash and say something like Siteworks is not available or something like that.  I had it do this to me in the middle of site cal right after I moved my base to the next set up.  When I shot the next control point I had a big vertical error which made me think that the HI was not carried over.  Now this presents a two fold issue.  I tried to reset my base with the correct HI since it still was holding the temp point name I shot to move my base up to.  This is when the crash happened and I lost everything.  Now I have to go back and start over again.  Maybe I shouldn't have tried to edit my base position or the software won't allow me to.  Either way I think there should be an option to edit that setup in the event something like this happens.  I use a fixed height tripod for my base so it usually always holds the same height every time I set it up once it has been set up on a job site.  I also think that when doing a site cal and using the moving base option Siteworks should save all the base positions you used to complete the calibration.  But hey that's just me.  Also, I am using the most up to date firmware 1.10 on a TSC7.  If someone could tell me where to find the error log/file I would gladly send it along. I have the Auto send diagnostics enabled so maybe it sent it already.
    Thanks,
    Ben
  • 2.  Re: Siteworks Crashing
    Posted 08-08-2019 08:28
    C:\Trimble Synchronizer Data\CONTROLLER\Trimble SCS900 Diagnostic Data is the folder usually where it stores the logs
  • 3.  Re: Siteworks Crashing
    Posted 08-08-2019 09:21
    Hi Ben,
    Yes, the logs will be in C:\Trimble Synchronizer Data\<CONTROLLER NAME>\Trimble Siteworks Diagnostic Data.
    We were just made aware of a potential bug in the heights while doing exactly that move base workflow, and I also agree that saving the intermediate base positions would be beneficial.
    So if you get those logs and can open a support case with your dealer, that is the proper way to handle crashes, so that we have a support ticket and the issue tracked properly.  Also, when doing the case, you can save a lot of back and forth by being sure to include a detailed description of the steps that cause the crash, and including the project folder, so that we can try to replicate it.
