EXPLODE SURFACE TML PROBLEM
  • 1.  EXPLODE SURFACE TML PROBLEM
    Posted 05-06-2020 08:33
    I am having problems running the Explode Surface TML.  It will work as long as I don't check the Only at slope break option.  When I do I get this error.  I tried various break angles ranging from 1-5.  Does anyone else have this problem?
    Thanks.
    Ben
  • 2.  Re: EXPLODE SURFACE TML PROBLEM
    Posted 05-09-2020 09:52
    Ben
    Have you updated with TML Status (both TML Status and the TML that is causing the traceback issue recently - can you do that and let me know if problem clears up - if not send .e the surface you are trying to explode and I will take a look for you
  • 3.  Re: EXPLODE SURFACE TML PROBLEM
    Posted 05-11-2020 12:07
    I am seeing this as well - I will get it fixed today Ben
  • 4.  Re: EXPLODE SURFACE TML PROBLEM
    Posted 05-12-2020 06:54
    I had not used this TML before. I was able to explode a Land XML surface with the angle set to 1. Then I used Data prep to connect all the lines. I updated the TML before I used it.
