SMART TEXT:  LINESTRING TO SURFACE DEPTH?
  • 1.  SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 11:32
    I am needing calculate the top of pipe under a road way to the bottom of the sub grade minus 6".  I understand how to get the smart text to give me the elevation of the to object and how to use the math function to offset the bottom of SG and how to offset the FL of the pipe to top of pipe and it will show the two elevations.  But i swear I saw on a demo somewhere and I can't seem to find it that it would calculate the depth then for you as well.  Can someone please show me how you do this?
    Thanks,
    Ben
  • 2.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 14:11
    Hi Ben,
    Thanks for posting that! I have the same question.
    I'd love to know how to combine two smart texts to show depth... or slope... (depth/distance).
    Cheers,
  • 3.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 19:12
    6Label the Line that crosses the Cut Fill Map to determine the "Depth to Invert" or "Depth to Top of Pipe" at different locations along the pipe. You can also use this to explore Depth of cover along a line to any surface. This is a great use of the Math in Smart Text also if you are given the line at Invert and you need the Depth of Cover to Top of Pipe - you can use the Math to add Depth to Invert = @<ELS,L,F,2,T>@
  • 4.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 19:17
    Depth to Crown = @<ELS,L,F,2,T|+0.5>@
    This is what you do if you want to add 0.5' to the Invert to get to Crown of Pipe to get real depth of cover
  • 5.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 19:53
    Is it possible to use something more than "Simple Math" ?
    Like: @<ELS,L,F,2,T> + <ELS,L,F,2,T>@
    instead of: @<ELS,L,F,2,T|*2>@
  • 6.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-01-2020 21:22
    I dont think that will be possible as that would require you to select a line 2x and the UI is not designed to do that
  • 7.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-02-2020 04:02
    Alan, what would I need to do to subtract a point elevation which is subgrade from a surface elevation at a location to give a delta value?
  • 8.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-02-2020 06:42
    Do the same as I did for the invert ie add the subgrade depth to the line elevation and if you want subgrade plus pipe crown then add the invert to crown distance to the subgrade depth to compute the depth from subgrade to crown
    This assumes that the subgrade depth is constant - if not then you would need to reference the subgrade surface not the design surface to get the depth of cover
  • 9.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-10-2020 13:23
    Alan, in the example below I'm grabbing finish grade from the surface model and existing grade from the point data. What smart text equation would I use to subtract EXSG from FG and display as a delta value (DEL=)?
    Thanks in advance,
    Tom
  • 10.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-10-2020 13:25
  • 11.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-10-2020 13:57
    Tom
    The Smart Text you need is as follows
    Elv: @<EL,O,F,2>@
    DElv: @<ELS,O,F,2,T,T>@
    The Elevation is of the Point and the DElv is the Cut Fill from the Point to the referenced surface.
    You can also do Mass Labeling of a lot of points using the Label Points command if you define a Label Style to do it - you have to have a different style for labels that reference different surfaces - here is the UI of the Label Style Editor for such a point label
  • 12.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-11-2020 15:38
    Alan, the mass labeling was the ticket. There is so much functionality in TBC that i don't use on a daily basis. I appreciate you taking the time to help us out!
    Tom
  • 13.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-11-2020 17:01
    Hey no problem Tom - I always wanted to be the "Oracle"
    On Thu, Jun 11, 2020 at 4:39 PM tmauriello@rlcos.com <trimble@jiveon.com>
  • 14.  Re: SMART TEXT:  LINESTRING TO SURFACE DEPTH?
    Posted 06-02-2020 08:40
    Thank you Alan.  This really is a powerful tool I will need to start getting more comfortable with in the creation of plan sets.
    Thanks Again,
    Ben
