Hey I was wondering if you can create points at station and offset using an alignment that has profile data? I want to create points where I snap and it will use the profile data for the elevations or if you wanted to create the points and a delta from the profile? Right now you have to tell it to use the profile for the elevation each time and it is too much clicking. I also tried the TML and I couldn't get it to hold the profile data either.
Thanks
Ben
