PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
  • 1.  PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 10-30-2020 09:38
    I was wondering if there was a way to pick along a 3D linestring at a set elevation on that line to say start a new line?
    It would be helpful in certain case where you need to tie into or start from a line string at say a whole elevation.
    Thanks,
    Ben
  • 2.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 10-30-2020 10:47
    I have thought about this before as well. It might be difficult with 3D lines though because there are multiple places this could occur. Not impossible though.
  • 3.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 10-30-2020 12:26
    VPI@Elevation Macro will give you what you are looking for. A vpi will be created at the station and elevation on the line that you desire and then you can create another linestring. After this, in the coordinate box, right click and snap to the end point where the vpi was created.
  • 4.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 10-31-2020 17:07
    Nick is correct - I would do this that way also
  • 5.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-03-2020 13:36
    Spin off Idea - the ability to create smart text along a line at certain elevations. Useful for creating call outs.
  • 6.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-03-2020 16:34
    Can you give me a work example - are you saying like label at every 0.25' elevation or something along a linestring like a flow line or a TBC or CL or Ditch Line etc. ?
  • 7.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-04-2020 02:54
    Correct. Flow lines, utilities alignments, face of building.
    Maybe 3 types of entry:
    Layout
    • select line
    • Select portion if desired, similar to the offset line
    • options to label
      • at interval
        • .25 ft, 5ft
        • At interval would allow users to quickly delineate spot grades on flatter sites for plan sets.
      • at elevation
        • Useful for roads and ditches but also useful for utilities for finding areas that meet clearance factors
        • At elevation could be used for design work to find spots where a linestring holds a particular elevation to had contours too.
      • at high or low points
        • This would place a spot grade at the lowest or highest point along a linestring
        • There is no automated way of doing this in tbc currently. Is there?
    • Text style
    • Text
      • allow users to do math
        • add.5ft for back of curb
        • Pipe clearance, pipe thickness
    • Leader: yes/no
  • 8.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-12-2020 07:17
    Here is an example I came across today
  • 9.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-03-2020 21:23
    End Snap will snap to VPIs also
  • 10.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-12-2020 07:44
    The only issue with this is my vertical snaps don't always show up.
  • 11.  Re: PICKING ALONG A LINESTRING AT A CERTAIN ELEVATION
    Posted 11-14-2020 20:29
    The snap indicators are not enabled on VPIs but they do work if your pick box is over the VPI it will pick the VPI location on the line.
