Point Clouds 3D transformation
  • 1.  Point Clouds 3D transformation
    Posted 11-27-2019 05:24
    Does anyone have experience with 3D transformation of point clouds between two different local coordinate systems? I can't find this function in TBC 5.10, but I don't have much experience with point clouds options, and I didn't find anything helpful in the help tab.
  • 2.  Re: Point Clouds 3D transformation
    Posted 11-27-2019 14:17
    I believe you have at least two options:
    1) Register Scans
    2) Geo-Reference Scans
    Option 1) would transform all overlapping scans to one local coordinate system of the reference scan
    Option 2) would independently geo-reference each individual scan into you global or local coordinate system providing you know coordinates of at least two points captured by each scan
    In TBC to to Support -> Help -> Type "register scans". Possible workflows are described in detail.
  • 3.  Re: Point Clouds 3D transformation
    Posted 12-09-2019 01:04
    Many thanks, that's what I was looking for :-)
    Best Regards,
    Jarek
  • 4.  Re: Point Clouds 3D transformation
    Posted 11-27-2019 19:13
    I use the Geo-Reference Scans. I will have the my screens split vertically. The global points on one screen and the local points and the point cloud on the other. I will then run the Geo-Reference Scans command.
    Hope this helps!
  • 5.  Re: Point Clouds 3D transformation
    Best Regards,
    Jarek
  • 6.  Re: Point Clouds 3D transformation
    Posted 12-12-2019 10:22
    Awesome work Marian - appreciate the input here - helpful
    Thanks
