Removing duplicate block definitions and Cad Text
  • 1.  Removing duplicate block definitions and Cad Text
    Posted 06-07-2019 08:09
    I think that the project cleanup tool is brilliant and use it a lot, but one of the things I wish it would do is remove duplicate CAD Text and block definitions.
    The problem i have is that a lot of the CAD imports I do, especially for updates to engineering layouts, import into the same layers as the previous iteration. The duplicate lines get removed using the project cleanup but the duplicate CAD text and blocks stay.
    I don't like deleting the previously imported version of the CAD file because quite often I have done hours or even days worth of work using the information.
  • 2.  Re: Removing duplicate block definitions and Cad Text
    Posted 06-07-2019 13:27
    You can use the Selection Set to isolate the data from each import and then delete Blocks and Text from the isolated data. We don't yet have a tool that can identify Text Duplicates or Block Duplicates at the same insert locations - but agree that would be useful to have.
    You aren't the first to ask for a tool like this - nor I am sure will you be the last.
    Requirement understood
  • 3.  RE: Removing duplicate block definitions and Cad Text
    Posted 10-22-2021 08:25
    Hello!  I came here hoping to have found an answer to this.   But! Now, I'm back, as I have now found a way!
    I have all the FG annotations in one layer, but from multiple import files. The CAD tech or whoever created the file used the same names for layers regardless of phase 1 or phase 3, which caused the same problem for me.
    Here's what I did: I selected everything on that layer, all the CAD text and arrows, and boxes. Under the macros tab, in the CAd section is a command called "convert to linestring"  After that I re-ran project cleanup and removed duplicate items.  BAM!!!! 697 duplicate items removed.
    Not sure if you ever found an alternative way or not, but here is an option. especially for those who come across your post.
    Cheers!
    NB
    Nathan Balcom
  • 4.  RE: Removing duplicate block definitions and Cad Text
    Posted 10-22-2021 08:47
    Ok, the duplicate boxes that are around the CAD elevations were deleted, still have multiples of the number itself.
    Nathan Balcom
  • 5.  RE: Removing duplicate block definitions and Cad Text
    Posted 10-26-2021 08:32
    I very much agree with you. Duplicate text can also bog down TBC.
    Patrick L'heureux
