Error importing Lidar laz file
  • 1.  Error importing Lidar laz file
    Posted 09-23-2020 06:04
    Dropbox - usgs18-70cm_14RMU995660.laz - Simplify your life
    Trying to import a laz file into TBC 5.32, but keep getting this error:
    It imports into Autodesk Recap just fine and I can export an e57 file and bring into TBC without any issues. I have checked several lidar files from the same source (TNRIS) and I get the error on the newer lidar's (2019) and not the old ones (2015). I know the old point clouds are version 1.2 and the new ones are 1.4. Does TBC not know how to handle the newest version of las/laz?
    I also checked the file on 5.30 and get the same error.
    Tommy
  • 2.  Re: Error importing Lidar laz file
    Posted 09-25-2020 05:29
    Has no one else seen this problem?
  • 3.  Re: Error importing Lidar laz file
    Posted 09-26-2020 07:47
    Tomas
    I am trying to find out what version of LAS and LAZ files we are supporting currently. It could well be that a Version Update has occurred that is not yet supported in TBC.
  • 4.  Re: Error importing Lidar laz file
    Posted 09-28-2020 11:05
    Thank you for the reply Alan
    Tommy
  • 5.  RE: Re: Error importing Lidar laz file
    Posted 03-17-2021 06:07
    Alan,
    Have you found out why we can't import this version of LAZ/LAS?
    Thomas Tomsu
  • 6.  RE: Error importing Lidar laz file
    Posted 03-18-2021 07:25
    You need to unzip the LAZ and convert it to a LAS file, there are free programs available online like the one pictured above.
    It is a bit clunky but it does work once you figure it out.
    Hope this helps.
    John Whidden
  • 7.  RE: Error importing Lidar laz file
    Posted 03-19-2021 08:29
    Edited by David Olander 03-19-2021 08:29
    If there is a version problem, I think you can use las2las.exe to modify the files. las2las.exe and laszip.exe were my 2 favorite applications in the LAS Tools suite. When exporting scan data, I intentionally kept my versions lower so that I didn't encounter compatibility issues. Generally, I stuck to version 1.1 or 1.2, depending upon whether I had RGB included. I never used them to convert from one version to another, but I'm pretty sure it can do that. Also, the GUI is shown above, but I preferred to use the command line.
    laz is a very effective format to store and use lidar/scan files. The .laz file is about 1/7 the size of the .las file it was created from and because these data sets tend to be very large, it equates to a significant reduction in storage required and download times. Most software can use .laz natively. I found that in using RiProcess, TBC, Microstation/TopoDOT and Civil3D, that there was rarely a reason to convert back to .las.
    Dave Olander
  • 8.  RE: Error importing Lidar laz file
    Posted 04-17-2023 09:05
    Would you help me? I try to export a .LAZ file For the program the same date, it only happens with LAZ files
    [Diego] [Mendes]
    [Analista suporte]
    [stefanini]
    [Ariquemes] [RO]
  • 9.  RE: Error importing Lidar laz file
    Posted 04-17-2023 16:31
    Are you asking for help with the original question, posted in 2020? I was able to import the original .laz file into a TBC v5.81 file, set up for NAD83(2011) UTM Zone 14N. The point cloud places itself west of Austin Texas, USA.
    Below is the LASInfo result for that LAZ file:
    M:\tbdoland\Equipment Data\Scanner\LAStools\bin>lasinfo.exe -i usgs*.laz
    lasinfo (230330) report for 'usgs18-70cm_14RMU995660.laz'
    reporting all LAS header entries:
      file signature:             'LASF'
      file source ID:             0
      global_encoding:            17
      project ID GUID data 1-4:   4D72BE80-024A-4A28-0000-000000000000
      version major.minor:        1.4
      system identifier:          'NIIRS10'
      generating software:        'GeoCue LAS Updater'
      file creation day/year:     284/2018
      header size:                375
      offset to point data:       1493
      number var. length records: 3
      point data format:          6
      point data record length:   30
      number of point records:    0
      number of points by return: 0 0 0 0 0
      scale factor x y z:         0.01 0.01 0.01
      offset x y z:               0 0 0
      min x y z:                  499500.00 3366000.00 585.03
      max x y z:                  500999.99 3367499.99 731.48
      start of waveform data packet record: 0
      start of first extended variable length record: 0
      number of extended_variable length records: 0
      extended number of point records: 14075116
      extended number of points by return: 8573506 3652361 1452112 345782 47061 4050 230 13 1 0 0 0 0 0 0
    variable length header record 1 of 3:
      reserved             0
      user ID              'LASF_Projection'
      record ID            2112
      length after header  918
      description          'OGC WKT Coordinate System'
        WKT OGC COORDINATE SYSTEM:
        COMPD_CS["NAD83(2011) / UTM zone 14N + NAVD88 height - Geoid12B (metre)",PROJCS["NAD83(2011) / UTM zone 14N",GEOGCS["NAD83(2011)",DATUM["NAD83_National_Spatial_Reference_System_2011",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","1116"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","6318"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-99],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","6343"]],VERT_CS["NAVD88 height - Geoid12B (metre)",VERT_DATUM["North American Vertical Datum 1988",2005,AUTHORITY["EPSG","5103"]],UNIT["metre",1],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","5703"]]]
    variable length header record 2 of 3:
      reserved             0
      user ID              'NIIRS10'
      record ID            4
      length after header  10
      description          'NIIRS10 Timestamp'
    variable length header record 3 of 3:
      reserved             0
      user ID              'NIIRS10'
      record ID            1
      length after header  26
      description          'NIIRS10 Tile Index'
    the header is followed by 2 user-defined bytes
    LASzip compression (version 3.3r1 c3 50000): POINT14 3
    reporting minimum and maximum for all LAS point record entries ...
      X            49950000   50099999
      Y           336600000  336749999
      Z               58503      73148
      intensity       16514      65535
      return_number       1          7
      number_of_returns   1          7
      edge_of_flight_line 0          1
      scan_direction_flag 0          0
      classification      1          7
      scan_angle_rank   -12         30
      user_data          54         55
      point_source_ID   474        475
      gps_time 200699460.339842 200699888.123246
      extended_return_number          1      9
      extended_number_of_returns      1      9
      extended_classification         1      7
      extended_scan_angle         -2000   5000
      extended_scanner_channel        1      2
    number of first returns:        8573506
    number of intermediate returns: 1849498
    number of last returns:         8572762
    number of single returns:       4920650
    overview over extended number of returns of given pulse: 4920650 4400409 3319382 1195019 215074 22954 1523 96 9 0 0 0 0 0 0
    histogram of classification of points:
             8271073  unclassified (1)
             5804030  ground (2)
                  13  noise (7)
     +-> flagged as withheld:  985270
      +--->          985270 of those are unclassified (1)
     +-> flagged as extended overlap: 3397448
      +--->         2440081 of those are unclassified (1)
      +--->          957367 of those are ground (2)
    Dave Olander
  • 10.  RE: Error importing Lidar laz file
    Posted 03-19-2021 11:33
    Thank you John for the info.
    I was just wandering when TBC could import these files as-is like other software can without having to convert them.
    Thomas Tomsu
