Station offset report, possible to do one wich dont include everything?
  • 1.  Station offset report, possible to do one wich dont include everything?
    Posted 09-28-2019 11:52
      |   view attached
    Hi!
    I have posted a VCL here. Is there anyway to get a station-offset report every 20m section from the CL alignment to the lines at the sides that DONT includes the lines points every 1m.
    I am loosing it here. The lines are from a corridor surface and i want to report how wide the bottom of the corridor is along the alignment but every time i try i just get to muck other stuff that i dont want. I just want the offsets every 20m but it seems impossible....Any ideas?
    Can someone help me out here, any takers?
    Attachment(s)
  • 2.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-28-2019 14:27
    I can try to take a look Fred - there is also a new TML Report called Cut Sheet Report that Rockpile Solutions have just finished up that does a nice job of reporting Corridors at defined intervals and also allows you to select what nodes you want to report and what values you want to report. I can take a look at your data to see if that report works - you can likely get a trial of the report from Rockpile if you ask them
    Will try to look at your data over the weekend
  • 3.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-28-2019 22:46
    I just e-mailed Rockpile, thanks for the tip!
  • 4.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-28-2019 16:37
    Fred
    I sent you a couple of report outputs - I hope they help - courtesy of Rockpiles TML Cut Sheet Report. I will see if we can also get the Sta / Off / Elev report out of what he has been doing also
  • 5.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-30-2019 06:08
    Rockpiles did give me a 30 day trial but i havent tried it yet. Right now the project (the same big one with the channel you and Tim looked at the last time) is painful slow again. i am now running on C: and it has worked fine but now it takes up to 2 minutes just when zooming in without any orthophotos or pointcloud visible. i am not sure but i think my problem started again after installing TML. Do you now how to uninstall it?
  • 6.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-30-2019 06:19
    I dont think the TML will have anything to do with it. You can deinstall it
    however by going to the following path and delete these files
    C:\ProgramData\Trimble\MacroCommands\RockpileSolutions
    CorridorCutSheet.pydll (or rename it to a different extension)
    TMLStatus.pydll (or rename it to a different extension)
    RockpileSolutions.dict (or rename its extension)
    RPSUtilities.pydll (or rename its extension)
    You can also cut them from here and paste elsewhere - like Desktop so TBC
    cannot find them
    I don't think this is the issue however but try it and see
    You will have to restart after removing the files
    And
    On Mon, Sep 30, 2019 at 7:08 AM fredrik@fredriksmarktjanst.nu <
  • 7.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 09-30-2019 09:09
    Thanks, i will try that but as you say its a long shot.
  • 8.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 10-01-2019 02:07
    Did uninstalling the TML files fix the speed issues?
  • 9.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 10-01-2019 04:15
    No - it is to do with Sheet Views / Plotting stuff that is causing their
    issues they think now
    On Tue, Oct 1, 2019 at 3:07 AM peter_kistler@rockpilesolutions.com <
  • 10.  Re: Station offset report, possible to do one wich dont include everything?
    Posted 10-01-2019 04:52
    Nope, that was not the issue as you and Alan said of course but i had to try.
    I have not used it yet but i will and also respond to your e-mail.
