You can also try using the Radial Surfaces function (I have posted videos
on this to the forum previously) - a Radial Surface can be added to a
Corridor Modeland you can then use it to slice section lines etc if you
need to show a 3D Shape of a Near Vertical or Overhanging Rock Surface etc.
I use that more than the Projected surface because of this specific reason.
You can also try the following - I did this for a Coastal Erosion project
recently
Create the Projected surface and export it to a DXF File (you can try using
Explode Surface that may also work these days - not sure. Import the DXF
3D Faces back in as linework. You can then draw on section lines in 2D and
then use the Elevate Lines by Intersecting Lines to drape the 2D lines over
the 3D Faces - you may have some cleanup to do afterwards - but that can
help define the faces with kind of section lines - where you have overhangs
will be the most problematic - you may need to break the section lines and
do them in parts and then join them together so as to get the Top and
Bottom of the overhangs etc.
Let me know if these ideas help - failing that I can try to look at this
later in the week
On Tue, Nov 12, 2019 at 4:22 AM Fredrik Bergström <trimble@jiveon.com>
