Hi!
Since i updated to 5.3 i have som scaling problems and i dont know why.
For example i have to multiply scale style with 100 to make lines show as they should and when switching to drafting lines are solid again. Texture on a surface looks good in planview as in the picture but not in sheetview, in there the scaling of the picture is to big. If i try to label a grid i cant se the text because its 100 times to small.
I have not changed anything in the settings and i dont know how to fix this, the problem did occur after uptating to 5.3.
Anyone know wich settings are wrong?
