To create a Radial Surface - create the point cloud region, create a HAL along the face (a straight line is what you need for this example. Make the HAL longer than the face. Use the Create Radial Surface command. The radial surface created change the properties to be Unwrap from Top.
You will need an Original Ground in the Corridor - if you don't have one create a simple plane at an elevation above the lip of the cut face and use that as the OG - the Corridor Earthwork report wont report unless you have that.
Run the Corridor Earthwork Report, report at eg 25cm intervals and look in the Areas section of the report (columns of the report) for the Surface Area of Finished Grade - that is the face area of the Radial Surface.
