XYZ to LAS?
  • 1.  XYZ to LAS?
    Posted 08-20-2019 07:37
    Hi!
    Is there a easy way to convert a XYZ file to .LAS format? I tried to import a 20MB XYZ (1 millin points) to TBC but that does not work.....;)
  • 2.  Re: XYZ to LAS?
    Posted 08-20-2019 12:43
    If the imported file has the extension .PTS it will automatically be created as a point Cloud as opposed to CAD POINTS (1000000 CAD Points is painful).
    It will import the CAD Points but it will take it a long time - just change the file extension and the data order is E N Z comma separated - provided you can get the data like that it can be imported as a point cloud.
    Once imported to TBC as a Point Cloud it can be exported as a Point Cloud format.
  • 3.  Re: XYZ to LAS?
    Posted 08-20-2019 13:30
    Great!! But how do i change the extension to .PTS? I tried to name the file test.PTS instead of test.XYZ but i just went test.PST.XYZ.
    Is there a converter or another way to change it?
  • 4.  Re: XYZ to LAS?
    Posted 08-20-2019 13:34
    I just do it in File Explorer - you can also do it saving from eg Notepad.
    You have to backspace over the .xyz and replace it with PTS
    On Tue, Aug 20, 2019 at 2:31 PM fredrik@fredriksmarktjanst.nu <
  • 5.  Re: XYZ to LAS?
    Posted 08-20-2019 13:43
    Strange, it still keeps the first filetype.
  • 6.  Re: XYZ to LAS?
    Posted 08-20-2019 14:37
    Fred - this is all I am doing in Windows File Explorer - this may be a Windows or File association thing - I am not sure
    Here is a video
  • 7.  Re: XYZ to LAS?
    Posted 08-23-2019 06:14
    Thanks for you help Alan, finally i did get it to work. This was perfect!
  • 8.  Re: XYZ to LAS?
    Posted 08-23-2019 06:22
    Good to hear - out of interest what was stopping you from renaming files?
    On Fri, Aug 23, 2019 at 7:14 AM fredrik@fredriksmarktjanst.nu <
  • 9.  Re: XYZ to LAS?
    Posted 08-23-2019 06:35
    I dont really know actually.
    When i just tried to rename the file as i showed you it did not work but when i did like this. it worked:
    Import to excel and saved it as a .csv
    Closed and opened the file with notes
    Choosed "save as" end shifted from ".txt" to "all files" in format an put the .pts in the file name.
    Then i worked.
  • 10.  Re: XYZ to LAS?
    Posted 08-23-2019 07:10
    Microsoft I guess ....
    On Fri, Aug 23, 2019 at 7:36 AM fredrik@fredriksmarktjanst.nu <
  • 11.  Re: XYZ to LAS?
    Posted 08-23-2019 07:20
    Probably
  • 12.  Re: XYZ to LAS?
    Posted 08-23-2019 09:42
    There is a setting in Windows explorer that prevents someone from unknowingly changing a files extension (very frustrating for someone who doesn't understand). That's probably what is happening.
    How to change a File Extension in Windows – FlexRadio Systems
