Cutting plane view, dont se surface
  • 1.  Cutting plane view, dont se surface
    Posted 08-17-2019 00:58
    Hi!
    This is probably a error 60 but i cant understand what i am missing here.
    I have a (almost) vertical surface wich i made by sideslope command and its suppose to represent a propertyline. I want to se this in the cutting plane wiev becaus i want to do a mesurement and take a screenshot to show my customer.
    I am pretty sure i did see the surface for a short time when i was working in the project but now i cant get it to show, what am i missing here?
  • 2.  Re: Cutting plane view, dont se surface
    Posted 08-20-2019 14:24
    The cutting plane view will show where the cutting plane slices the Triangle Faces - best is when the Cutting Plan has a decent depth eg 10 or 20 feet (10m for you), If you click on the line that shows the surface it will reveal the surface mesh - however maybe this view is not the best to do this with - I would try the Limit Box instead as that show the Surface sliced and solid rendered and I think gives a better picture of what you are trying to achieve
