Best scan export from SX10 when having scans from different times
  • 1.  Best scan export from SX10 when having scans from different times
    Posted 02-15-2019 01:48
    Hi!
    What is the best workflow for exporting data from the SX10 to TBC when we have scans from different times?
    We have a project that we did a scan 6 month ago and now we scanned it again. But when we bring out the data rom our T10 tablet we just take the folder for the project and drag n drop it in the project.
    But now we have more scans from that project and i just want to import them together with their pictures. How do i do that without importing all scans again?
  • 2.  Re: Best scan export from SX10 when having scans from different times
    Posted 02-15-2019 14:18
    For each set of scans I normally create a Point Cloud Region for each Time Period and add all the Scan Data from that Time Region to it. That clears out the "Default Scan" so it can receive the next time period of data. Then you have a Master point Cloud Region for Each Time Period that you can manipulate individually.
    Where there are Scans and Photos I have never done that personally so the Geospatial Team would have to answer it. If you want to share a number of Time range sets of data with me, I can work through this and give you a suggestion next week on the best workflow
    Apologies but the SX10 falls in Geospatial Team and I typically just work with the point Clouds - I can work on the other parts but I dont have any example data personally for this
  • 3.  Re: Best scan export from SX10 when having scans from different times
    Posted 02-16-2019 07:08
    Thanks for your answer Alan, that helped me. I will put together some data.
