Pointcloud invisible
  • 1.  Pointcloud invisible
    Posted 11-18-2018 11:47
    Hi!
    I had a huge problem when i imported a .XYZ-file, the pointcloud did not show up in the plan view but in the 3D-view i could see it sometimes. All other pointclouds i have been workin with has worked perfectly but not this .XYZ-file.
    The problem is now solved and look att the video here and you can see how to fix it if it happens to you.
    Have a nice sunday.
  • 2.  Re: Pointcloud invisible
    Posted 11-18-2018 18:45
    Thanks for posting the update Frederik - glad we got t working for you
    Point Cloud - Visibility Mode was set to "See Inside Visibility Mode" - changing it to No Visibility Mode cured the issue
