Hi, this is 2 Questions in one.
First of all, can someone try to import this .XML and see if it works? We are 2 people running HCE 4.12 and when we import the file BC says the file is damaged and cant be used, on 2 different computers. But on a third computer the import works fine, also running 4.12.
The second question, when we imported the file the surface got a hole in one place (this happen sometimes with surfaces and i dont know why) and i cant close the hole. I tried to dra a linte around the hole and adeed it to the surface but it did not work. I had to export the surface as a ttm and import it as 3D lines and made a new surface, then it worked!
Anybody having the same issues?
See you in Vegas!
