Many times I add 3D linework to a corridor using the Surface Members feature to add features that are difficult to create in a corridor model. Many times I get flags that inform me the linework between the two surfaces do not match or that an overlap has occurred causing a discrepancy. In the past I would simply remove the linework, edit it and the add it back to the corridor model and rerun the surface.
In this instance I can see that the linework is correct but the surface has yet to "rebuild" correctly.
I am uploading the corridor in the hope that maybe someone wiser and smarter can point me in the right direction. The VCL has the few flags I am trying to remove and the linework that I cannot get the surface to adhere to.
Any help would be appreciated.
