When digitizing pdf cross sections, it would be nice if when in the digitizing window, a right click would also give an option to create a point based on station and offset rather than having to left click a point then select that point with a right click and entering the station and offset. It would also make the process faster if a tab would highlight the offset field for editing and a following tab would highlight elevation field for editing.
