"it seems that you want to have new layer for every set of alignments..." Yes and No. The project you are currently viewing and I am working on is 9 intersecting side streets, 1 major crossing street (under) the mainline, 3 parallel railroads, 2 bridges, 96 total driveways (17 of which intersect the mainline), 5 retaining walls, two bridges, and 1 additional side street with a railroad crossing. Of those 115 alignments I have the major roadways stationed in seperate layers with the added suffix Lab. Driveways and walls aren't labeled; however if I did so I would likely label all the driveways, "Driveways Lab" and "Retaining Walls Lab". My thought process here is that I have "Design - View Filter" set for each design. When I am able to use vcl's for Works Manager, I will no longer require the labeling for the data collector; however, I will still need it for my own visualization and that of the machine control, catalyst, and sitevision designs.
"Alignment Label Sets that are in the project and the Alignment Name that they belong to, and you could turn them On / Off in a single dialog - would that not be a better solution" Yes, but how would that work for just one alignment? Would we be able to pick and choose which we see and which we don't, can we group them?
I am sending you a seperate link to your email containing the file.
