TBC "Select Observation" function deselecting features
  • 1.  TBC "Select Observation" function deselecting features
    Posted 01-09-2020 06:12
    I am running TBC 5.20 and I am trying to use "Select Observations" to select vectors with a vertical precision greater than a specified value.  When I select apply, TBC selects the vectors that meet the criteria, but then deselects them immediately.  With the properties tab up I can see there are 5 out of the 200 vectors were briefly selected, so I know the function is working correctly, it is just deselecting them.  Anyone have a workaround?
    Thanks,
    Mike
  • 2.  Re: TBC "Select Observation" function deselecting features
    Posted 01-21-2020 13:38
    Hi Michael,
    Sorry for the late reply, but I tried using the same observation in TBC 5.20 and the command selected my vectors correctly. Are you still seeing this issue yourself?
    If you're still looking for a workaround, I suggest you use the vector spreadsheet and sort using the V. Precision column. You can also filter using the spreadsheet by choosing a numerical range you'd like your vectors' precision to have.
    -Josh
  • 3.  Re: TBC "Select Observation" function deselecting features
    Posted 01-23-2020 08:42
    It is working now, must have been a fluke.
    Thanks
