So after a bit of testing both methods work well.
Alan I will give you credit as your colours look prettier.
Although 20 minutes manually, if this were written into a macro it would significantly less.
I guess its time to dust off the C# books and get cracking.
Gary, macro works great thanks for the add in.
To join the lines up I enquired the min and max elevations (eg 450 - 550),
Selected by Elevation using the above range,
Join lines,
Done.
One function I couldnt enquire in TBC was the berm angle (vertical angle) to nominate the Break Angle
In mining its typically expressed from a 90 deg Zenith
eg a steep wall is about 60 deg.
Are there any ways to measure this?
Cheers
