Corrdior earthworks report
  • 1.  Corrdior earthworks report
    Posted 06-22-2018 14:00
      |   view attached
    When I generate the corridor earthworks reports, I am not getting the quantities of the sub-grade per station increment.
    I am getting only the cut and fill.
    check a screen shot of my report attached. as you can see I have the subgrade material total:
    Eng-Fill = 301.5 m3
    Topping = 55.1 m3
    and below in the station increment it shows only the cut and fill for 0+010, 0+020, 0+030.
    any help to see the subgrade also???
    thanks in advance
  • 2.  Re: Corrdior earthworks report
    Posted 06-22-2018 15:23
    You have to use the excel report not the concise report.
    In the Corridor earthworks report options screen, go to the top of it and click the small icon called "report options"
    From there go to content style and change it from concise to Launch Excel data.
    That should give you what you want then.
  • 3.  Re: Corrdior earthworks report
    Posted 06-28-2018 12:26
    Thanks Jonathan
  • 4.  Re: Corrdior earthworks report
    Posted 06-22-2018 16:38
    Thanks Jon - you are correct on that one for sure
