When i try to open feature code processing file in Project setting TBC 4.12, it give an error saying invalid file.Any body have a solution for this?
just drag and drop the fxl file into the project Sami - I never got that setting to work in my default project in that version of BC-HCE - apologies
Still not working ,
All i did make a copy of the default file and changed some codes. Saved and when i drag and drop give the above error
You may have a versioning issue - if you created it or edited it in the
latest FXL Editor, that likely is not backwards compatible with 4.12
On Tue, Jun 4, 2019 at 12:14 PM sami.akiki@kiewit.com <trimble@jiveon.com>
It worked in Version 5.0 but not 4.12
Correct
On Tue, Jun 4, 2019 at 1:36 PM sami.akiki@kiewit.com <trimble@jiveon.com>
