Error when create a boundary in TBC 5.1
  • 1.  Error when create a boundary in TBC 5.1
    Posted 06-11-2019 08:10
    Any body have this Error when you start creating a boundary in 5.1 ?
    see the error below
  • 2.  Re: Error when create a boundary in TBC 5.1
    Posted 06-11-2019 13:40
    This is not a specific Draw Boundary problem, it is a data issue in the project that is causing this to throw. Can you share the project so we can take a look at the data and see what is causing this to throw the exception. You can mail it to me at alan_sharp@trimble.com and I will take a look
  • 3.  Re: Error when create a boundary in TBC 5.1
    Posted 06-13-2019 14:20
    Hi Alan,
    It happend to any empty new file. Not to a specific file.
    As soon i choose from the menu Cad/LineString/Boundary using Creation method (Polygon)., i choose the first point on the screen and when i click a second point it pop up the error.
  • 4.  Re: Error when create a boundary in TBC 5.1
    Posted 06-13-2019 14:24
    Sounds like an issue with your prototype project - try it in an empty
    project using a different prototype - looks like maybe the project Proto
    had some data that was deleted and that is throwing the null reference
    exception. If you can send me a project (do a file new - select the
    prototype project that is giving you the problem. Draw an object like a
    line or point. Save the project and email me the VCL file and I can take a
    look to see if we can find what is throwing the error.
    On Thu, Jun 13, 2019 at 3:20 PM sami.akiki@kiewit.com <trimble@jiveon.com>
  • 5.  Re: Error when create a boundary in TBC 5.1
    Posted 06-28-2019 12:05
    Sami
    I have tested here the exact same workflow with TBC v5.1 and it does not do what yours is doing. I also tested in BC-HCE v4.12 and I don't see what you are seeing either.
    In my case after I click the first points when I don't give it a name it flags the Name Field and tells me to enter a valid name before it allows me to continue
    What do you have your snaps set to?
    When that Exception throws, can you click in the box, do a CTRL A to select All, CTL C to Copy and then Paste it to an email and send it to me.
    You say that the Exception throws in any new project created with any Template?
    Since I cannot reproduce it at my end it is hard for me to give you more guidance - the Exception Error would be good to get so the dev team can see what is tripping the error in your system.
  • 6.  Re: Error when create a boundary in TBC 5.1
    Posted 06-28-2019 12:22
    HEllO  Alan,
    Do you have skype to share with you live my Desktop ?
  • 7.  Re: Error when create a boundary in TBC 5.1
    Posted 06-28-2019 13:28
    Exception Count:       1
    Exception Source:      Trimble.Vce.UI.ConstructionCommands
    Exception Type:        System.NullReferenceException
    Exception Message:     Object reference not set to an instance of an object.
    Exception Target Site: DrawLine
    Stack Trace -
        Trimble.Vce.UI.ConstructionCommands.CustomCursor.DrawLine(I2DProjection CtrlProjection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00373
        Trimble.Vce.UI.ConstructionCommands.CustomCursor.GenerateDrawingInstructions(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00058
        Trimble.CustomControl.Cursors.GdiCursorBase.Show(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.ViewModel.DLL : N 00149
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.ShowGdiCursor(Object sender, GdiCursorEventArgs e)
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00085
        Trimble.CustomControl.InputComponents.MouseInputComponent.OnShowGdiCursor(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.ViewModel.DLL : N 00130
        Trimble.CustomControl.InputComponents.AnchoredAtPointMouseInputComponent.ShowCursorHandler(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition, ShowCursorArgs args)
        Trimble.Vce.ViewModel.DLL : N 00977
        System.Action`4.Invoke(T1 arg1, T2 arg2, T3 arg3, T4 arg4)
        mscorlib.dll : N 00000
        Trimble.CustomControl.InputComponents.MouseInputComponent.ShowCursorHandler(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.ViewModel.DLL : N 00093
        Trimble.Vce.UI.Controls.ShowCursorHandlerCollection.Invoke(ICollection viewCollection, IViewSupportsCursor messagingView, Point mousePosition)
        Trimble.Vce.UI.Controls.DLL : N 00034
        Trimble.Vce.UI.Controls.GestureDispatcher.DispatchShowCursor(ShowCursorHandlerCollection handlerCollection, IViewSupportsCursor view, Point mousePosition)
        Trimble.Vce.UI.Controls.DLL : N 00093
        Trimble.Vce.UI.Controls.MouseFeedback.ShowCursor(IViewSupportsCursor view, Point mousePosition)
        Trimble.Vce.UI.Controls.DLL : N 00073
        Trimble.Vce.UI.Controls.HoopsViewBase.ShowGdiCursor(Point position)
        Trimble.Vce.UI.Controls.DLL : N 00047
        Trimble.Vce.UI.Controls.HoopsViewBase.ShowDispatcherCursor()
        Trimble.Vce.UI.Controls.DLL : N 00372
        Trimble.Vce.UI.Controls.IdleState.ProcessMessage(Object message)
        Trimble.Vce.UI.Controls.DLL : N 02735
        Trimble.Vce.Core.StateMachine.Machine.ProcessMessage(Object message)
        Trimble.Vce.Core.DLL : N 00027
        Trimble.Vce.UI.Controls.HoopsViewBase.Trimble.CustomControl.Interfaces.IViewSupportsCursor.RequestCursorShow()
        Trimble.Vce.UI.Controls.DLL : N 00384
        Trimble.Vce.UI.Controls.GestureDispatcher.RedisplayCursor()
        Trimble.Vce.UI.Controls.DLL : N 00157
        System.Reactive.ObserverBase`1.OnNext(T value)
        System.Reactive.Core.DLL : N 00019
        Trimble.CustomControl.Controllers.CoordinateEditController.DefineCursor()
        Trimble.Vce.ViewModel.DLL : N 00057
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.SetRubberLineAnchor()
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00122
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.FirstPoint_ValueChanged(ValueChangedEventArgs e)
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00181
        Trimble.CustomControl.Controllers.CustomControlControllerImplementation.OnValueChanged(ValueChangedEventArgs e)
        Trimble.Vce.ViewModel.DLL : N 00060
        Trimble.CustomControl.Controllers.CoordinateEditController.SetCoordinate(Point3D point, IProject inputProject, InputMethod inputMethod, ICoordinateSystemDefinition csd, IViewSupportsCursor view)
        Trimble.Vce.ViewModel.DLL : N 00652
        Trimble.Vce.UI.Controls.CoordinateEdit.SetCoordinate(Point3D point, IProject inputProject, InputMethod inputMethod, ICoordinateSystemDefinition csd, IViewSupportsCursor view)
        Trimble.Vce.UI.Controls.DLL : N 00045
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.MoveAdditionalPtToFirstPoint()
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00145
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.DoAction()
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00093
        Trimble.Vce.UI.ConstructionCommands.CreateBoundaryCmdUI.AdditionalPoint_ValueChanged(ValueChangedEventArgs e)
        Trimble.Vce.UI.ConstructionCommands.DLL : N 00144
        Trimble.CustomControl.Controllers.CoordinateEditController.ProcessNewPoint(IMemberManagement sendingViewContainer, Point3D pointInViewContainer, IViewSupportsCursor snappedView, Point3D snappedPoint, SnapMode snappedMode, UInt32 snappedOnEntity, InputMethod inputMethod)
        Trimble.Vce.ViewModel.DLL : N 01205
        Trimble.CustomControl.Controllers.CoordinateEditController.MouseUpInView(IViewSupportsCursor sendingView, IMouseEventArgsAdapter e)
        Trimble.Vce.ViewModel.DLL : N 02259
        Trimble.CustomControl.InputComponents.MouseInputComponent.MouseUpHandler(IViewSupportsCursor sendingView, IMouseEventArgsAdapter mouseEventArgs)
        Trimble.Vce.ViewModel.DLL : N 00055
        Trimble.Vce.UI.Controls.VMouseHandlerCollection.Invoke(IViewSupportsCursor view, IMouseEventArgsAdapter eArgs)
        Trimble.Vce.UI.Controls.DLL : N 00024
       Trimble.Vce.UI.Controls.GestureDispatcher.DispatchMouseUp(IViewSupportsCursor view, IMouseEventArgsAdapter eArgs)
        Trimble.Vce.UI.Controls.DLL : N 00038
        Trimble.Vce.UI.Controls.HoopsViewBase.DispatchMouseUp()
        Trimble.Vce.UI.Controls.DLL : N 00404
        Trimble.Vce.Core.StateMachine.Machine.ChangeToState(Type stateType, Action transitionAction)
        Trimble.Vce.Core.DLL : N 00118
        Trimble.Vce.Core.StateMachine.Machine.ChangeToState(Type stateType)
        Trimble.Vce.Core.DLL : N 00011
        Trimble.Vce.UI.Controls.RemoteFeedState.ProcessMessage(Object message)
        Trimble.Vce.UI.Controls.DLL : N 00370
        Trimble.Vce.UI.Controls.HoopsViewBase.OnMouseUp(MouseEventArgs e)
        Trimble.Vce.UI.Controls.DLL : N 00106
        System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
        System.Windows.Forms.dll : N 00721
        System.Windows.Forms.Control.WndProc(Message& m)
        System.Windows.Forms.dll : N 02426
        Trimble.Vce.UI.Controls.HoopsViewBase.WndProc(Message& m)
        Trimble.Vce.UI.Controls.DLL : N 00480
        System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
        System.Windows.Forms.dll : N 00194
    Date and Time:      6/28/2019 4:26:58 PM
    Machine Name:       A-70K2CG2
    IP Address:         fe80::91a6:632e:c52b:a84b%8, 1::de, fe80::4cb0:1abe:8654:5b75%2, 10.251.124.251, 192.168.2.168,
    Current User:       KIEWITPLAZA\sami.akiki
    Application Domain: TrimbleBusinessCenter.exe
    Thread Name:        Office UI Thread
    Assemblies in AppDomain -
    Assembly Full Name:  mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    Assembly Full Name:  TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
    Assembly Full Name:  Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
    Assembly Full Name:  System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    Assembly Full Name:  System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    Assembly Full Name:  System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Assembly Full Name:  Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinToolbars.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v18.2.DLL
    Assembly Full Name:  Trimble.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.DiskIO.DLL
    Assembly Full Name:  System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    Assembly Full Name:  System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Assembly Full Name:  System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Assembly Full Name:  Trimble.Vce.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Interfaces.DLL
    Assembly Full Name:  Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinDock.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
    Assembly Full Name:  Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
    Assembly Full Name:  Trimble.Vce.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DLL
    Assembly Full Name:  Trimble.Vce.Data.SDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.DLL
    Assembly Full Name:  Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
    Assembly Full Name:  TD_SwigCoreMgd, Version=19.8.0.0, Culture=neutral, PublicKeyToken=8e28356228e490a2
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigCoreMgd.DLL
    Assembly Full Name:  TD_SwigDbMgd, Version=19.8.0.0, Culture=neutral, PublicKeyToken=5ccc28765cdf0a88
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigDbMgd.DLL
    Assembly Full Name:  Trimble.Vce.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Core.DLL
    Assembly Full Name:  System.IO.Compression.FileSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
    Assembly Full Name:  Trimble.Vce.License, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.License.DLL
    Assembly Full Name:  Gibraltar.Agent, Version=4.5.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Gibraltar.Agent.DLL
    Assembly Full Name:  hasp_net_windows, Version=5.11.1.23192, Culture=neutral, PublicKeyToken=56120be447701319
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hasp_net_windows.DLL
    Assembly Full Name:  System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    Assembly Full Name:  Infragistics4.Win.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.v18.2.DLL
    Assembly Full Name:  Infragistics4.Shared.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Shared.v18.2.DLL
    Assembly Full Name:  UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
    Assembly Full Name:  Trimble.Trdm.ServiceManagement, Version=2.5.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.ServiceManagement.DLL
    Assembly Full Name:  Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Assembly Full Name:  System.Management, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Assembly Full Name:  System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    Assembly Full Name:  Infragistics4.Win.Misc.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v18.2.DLL
    Assembly Full Name:  System.Reactive.Linq, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Linq.DLL
    Assembly Full Name:  System.Reactive.Interfaces, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Interfaces.DLL
    Assembly Full Name:  System.Reactive.Core, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Core.DLL
    Assembly Full Name:  Trimble.Vce.Utils, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Utils.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinTabbedMdi.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Coordinates.DLL
    Assembly Full Name:  Trimble.Vce.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Geometry.DLL
    Assembly Full Name:  Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
    Assembly Full Name:  WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    Assembly Full Name:  System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    Assembly Full Name:  Infragistics4.Win.UltraWinStatusBar.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v18.2.DLL
    Assembly Full Name:  Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinExplorerBar.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v18.2.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinEditors.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v18.2.DLL
    Assembly Full Name:  UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
    Assembly Full Name:  Infragistics4.Win.UltraWinGrid.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.UI.Controls.PropertyGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
    Assembly Full Name:  System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
    Assembly Full Name:  Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
    Assembly Full Name:  Trimble.Vce.Data.Machine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.DLL
    Assembly Full Name:  Trimble.Vce.Data.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.DLL
    Assembly Full Name:  Trimble.Core.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
    Assembly Full Name:  Trimble.Trdm.Contracts, Version=2.5.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.Contracts.DLL
    Assembly Full Name:  netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
    Assembly Full Name:  System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
    Assembly Full Name:  SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
    Assembly Full Name:  System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
    Assembly Full Name:  System.ServiceModel.Primitives, Version=4.5.0.3, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.ServiceModel.Primitives.DLL
    Assembly Full Name:  System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
    Assembly Full Name:  System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
    Assembly Full Name:  Trimble.Vce.Data.SCS.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.Utilities.DLL
    Assembly Full Name:  System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
    Assembly Full Name:  Microsoft.Extensions.DependencyInjection.Abstractions, Version=2.2.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
    Assembly Full Name:  Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InjectDependencies.DLL
    Assembly Full Name:  Trimble.Vce.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Persistence.DLL
    Assembly Full Name:  Microsoft.Extensions.DependencyInjection, Version=2.2.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.DLL
    Assembly Full Name:  Trimble.Vce.Collections, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Collections.DLL
    Assembly Full Name:  Trimble.Vce.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ForeignCad.DLL
    Assembly Full Name:  Trimble.Vce.Data.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RawData.DLL
    Assembly Full Name:  Trimble.Geodetic.Math, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Math.DLL
    Assembly Full Name:  Trimble.Core.Gdtic, Version=4.60.82.3, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.Gdtic.DLL
    Assembly Full Name:  Trimble.Geodetic.Optical, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Optical.DLL
    Assembly Full Name:  Trimble.Vce.GE.Base, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Base.DLL
    Assembly Full Name:  Trimble.Vce.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Reports.DLL
    Assembly Full Name:  Trimble.Geodetic.Reductions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Reductions.DLL
    Assembly Full Name:  Trimble.Vce.Alignment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Alignment.DLL
    Assembly Full Name:  Trimble.Vce.Data.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Construction.DLL
    Assembly Full Name:  Trimble.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Properties.DLL
    Assembly Full Name:  Trimble.Vce.Gem, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Gem.DLL
    Assembly Full Name:  Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
    Assembly Full Name:  Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
    Assembly Full Name:  System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
    Assembly Full Name:  Trimble.Vce.Data.GNSSData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GNSSData.DLL
    Assembly Full Name:  Trimble.Vce.Data.Results, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Results.DLL
    Assembly Full Name:  Trimble.Vce.Data.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Scanning.DLL
    Assembly Full Name:  Sde.NET, Version=2.8.4.299, Culture=neutral, PublicKeyToken=fa7d95db1187f161
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Sde.NET.DLL
    Assembly Full Name:  PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    Assembly Full Name:  Trimble.Vce.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Features.DLL
    Assembly Full Name:  Trimble.Vce.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.FeatureDefinitions.DLL
    Assembly Full Name:  CommonCore, Version=4.5.9.127, Culture=neutral, PublicKeyToken=385de07dd97ef61c
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/CommonCore.DLL
    Assembly Full Name:  Trimble.Vis.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Model.DLL
    Assembly Full Name:  Trimble.Vce.Data.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MobileMapping.DLL
    Assembly Full Name:  Sdm.NET, Version=2.8.4.299, Culture=neutral, PublicKeyToken=fa7d95db1187f161
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Sdm.NET.DLL
    Assembly Full Name:  Trimble.Vce.Epm, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
    Assembly Full Name:  Splat, Version=1.6.2.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Splat.DLL
    Assembly Full Name:  Trimble.Vce.ReportEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
    Assembly Full Name:  Microsoft.ReportViewer.WinForms, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.WinForms.DLL
    Assembly Full Name:  Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
    Assembly Full Name:  BellbirdInterfaces, Version=1.1.6680.18676, Culture=neutral, PublicKeyToken=e46c466c63fb6536
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/BellbirdInterfaces.DLL
    Assembly Full Name:  Trimble.Vce.Data.UASMaster, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
    Assembly Full Name:  Trimble.Vce.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
    Assembly Full Name:  Trimble.Vce.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Units.DLL
    Assembly Full Name:  System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    Assembly Full Name:  PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    Assembly Full Name:  ReactiveUI, Version=7.2.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinTree.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.UI.PPCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
    Assembly Full Name:  Trimble.Vce.UI.Wrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
    Assembly Full Name:  Trimble.Vce.UI.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
    Assembly Full Name:  nunit.framework, Version=3.10.1.0, Culture=neutral, PublicKeyToken=2638cd05610744eb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/nunit.framework.DLL
    Assembly Full Name:  Trimble.Vce.UI.ConstructionCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
    Assembly Full Name:  Trimble.Vce.UI.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
    Assembly Full Name:  Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
    Assembly Full Name:  Trimble.Vis.Tools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
    Assembly Full Name:  Trimble.Vce.UI.ConstructionReports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
    Assembly Full Name:  Trimble.Vce.Data.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Tests.DLL
    Assembly Full Name:  Trimble.Vce.Functions.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinChart.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v18.2.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinListView.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
    Assembly Full Name:  Trimble.Vce.UI.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
    Assembly Full Name:  Trimble.Vce.UI.ScanningCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
    Assembly Full Name:  Trimble.Vce.UI.ScsCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
    Assembly Full Name:  Trimble.SCS_WorkOrder, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
    Assembly Full Name:  Trimble.Vce.UI.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
    Assembly Full Name:  DataInteroperabilityComponent, Version=1.3.0.1, Culture=neutral, PublicKeyToken=3c2e0c2def562052
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
    Assembly Full Name:  Trimble.Vce.UI.GNSS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
    Assembly Full Name:  Trimble.Vce.UI.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
    Assembly Full Name:  NTJV.UI.CracksControl, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.CracksControl.DLL
    Assembly Full Name:  Trimble.Vce.TTMetrics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.TTMetrics.DLL
    Assembly Full Name:  Trimble.Vce.UI.MobileMappingCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.DLL
    Assembly Full Name:  System.Runtime.Serialization.Formatters.Soap, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
    Assembly Full Name:  Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Assembly Full Name:  Trimble.Vis.PdfImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
    Assembly Full Name:  Trimble.Vce.Data.Import, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
    Assembly Full Name:  Trimble.Core.CSDUI.MVP, Version=3.1.2.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
    Assembly Full Name:  Trimble.Vce.Data.REB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
    Assembly Full Name:  Trimble.Vce.Data.ComputationEngine2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.DLL
    Assembly Full Name:  Trimble.Vce.Data.LandXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.DLL
    Assembly Full Name:  Infragistics4.Win.SupportDialogs.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v18.2.DLL
    Assembly Full Name:  Trimble.Vce.UI.INetDownload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
    Assembly Full Name:  Trimble.Vce.UI.CoreCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
    Assembly Full Name:  Trimble.Vis.UI.TccCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
    Assembly Full Name:  Trimble.Vis.UI.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
    Assembly Full Name:  Trimble.Vis.UI.PdfCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.PdfCommands.DLL
    Assembly Full Name:  Takeoff.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.DLL
    Assembly Full Name:  Takeoff.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.DLL
    Assembly Full Name:  System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
    Assembly Full Name:  Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
    Assembly Full Name:  Trimble.Vce.Services.WeoGeo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
    Assembly Full Name:  Trimble.Vce.Services.Bentley, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
    Assembly Full Name:  System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
    Assembly Full Name:  Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Newtonsoft.Json.DLL
    Assembly Full Name:  Trimble.Identity, Version=1.0.0.0, Culture=neutral, PublicKeyToken=33101ee013558559
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Identity.DLL
    Assembly Full Name:  System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
    Assembly Full Name:  Microsoft.Scripting, Version=1.2.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Scripting.DLL
    Assembly Full Name:  IronPython, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.DLL
    Assembly Full Name:  Microsoft.Dynamic, Version=1.2.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Dynamic.DLL
    Assembly Full Name:  IronPython.Modules, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Modules.DLL
    Assembly Full Name:  Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    Assembly Full Name:  IronPython.Wpf, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Wpf.DLL
    Assembly Full Name:  Snippets.scripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    Assembly Full Name:  System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
    Assembly Full Name:  System.Reactive.PlatformServices, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.PlatformServices.DLL
    Assembly Full Name:  System.Reactive.Windows.Threading, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Windows.Threading.DLL
    Assembly Full Name:  Trimble.IS.IPPxGate, Version=6.1.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
    Assembly Full Name:  System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
    Assembly Full Name:  System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
    Assembly Full Name:  Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
    Assembly Full Name:  Infragistics4.Win.UltraWinSchedule.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v18.2.DLL
    Assembly Full Name:  WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
    Assembly Full Name:  PresentationFramework.Aero2, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
    Assembly Full Name:  PresentationFramework-SystemXmlLinq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
    Assembly Full Name:  PresentationFramework-SystemXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    Assembly Full Name:  Trimble.Vce.Bridge, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Bridge.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinDataSource.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDataSource.v18.2.DLL
    Assembly Full Name:  Infragistics4.Win.UltraWinTabControl.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabControl.v18.2.DLL
    Assembly Full Name:  Trimble.WPD.Combined, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.Combined.DLL
    Assembly Full Name:  Trimble.Vce.Data.ScJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
    Assembly Full Name:  Trimble.Vce.Data.GeneralSurvey, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
    Assembly Full Name:  Trimble.Vce.Data.FieldBookJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
    Assembly Full Name:  Trimble.Vce.Data.MercuryJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
    Assembly Full Name:  Trimble.Vce.Data.TDS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
    Assembly Full Name:  Trimble.Vce.Data.SpJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
    Assembly Full Name:  Trimble.Vce.Data.GeoNav, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
    Assembly Full Name:  Trimble.Vce.Data.AshtechJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
    Assembly Full Name:  PresentationFramework-SystemData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
    Assembly Full Name:  Trimble.Vce.SurveyCAD, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.SurveyCAD.DLL
    Assembly Full Name:  Trimble.Vce.Data.RawData.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RawData.Tests.DLL
    Assembly Full Name:  System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
    Assembly Full Name:  Trimble.Vce.InSphere.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
    Assembly Full Name:  hoops_mvo2320_cs141, Version=23.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops_mvo2320_cs141.DLL
    Assembly Full Name:  hoops2320_cs141, Version=23.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops2320_cs141.DLL
    Assembly Full Name:  WSegmentationManager_x64, Version=0.0.0.0, Culture=neutral, PublicKeyToken=c8536b94f39c562b
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/WSegmentationManager_x64.DLL
    Assembly Full Name:  hoops_stream2320_cs141, Version=23.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops_stream2320_cs141.DLL
    Assembly Full Name:  Trimble.Vce.GE.Sde, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Sde.DLL
    Assembly Full Name:  Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Core.DLL
    Assembly Full Name:  Trimble.Vce.GE.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Hoops.DLL
    Assembly Full Name:  System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
    Assembly Full Name:  System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
    Assembly Full Name:  System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
    Assembly Full Name:  System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
    Assembly Full Name:  System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
    Assembly Full Name:  System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
    Assembly Full Name:  System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
    Assembly Full Name:  System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    Assembly Full Name:  System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.ApplicationServices/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.ApplicationServices.dll
    Assembly Full Name:  Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.Build.Framework/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.Build.Framework.dll
    Assembly Full Name:  Trimble.Vce.Reports.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Reports.Tests.DLL
    Assembly Full Name:  Microsoft.ReportViewer.Common, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.Common.DLL
    Assembly Full Name:  Microsoft.ReportViewer.ProcessingObjectModel, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.ProcessingObjectModel.DLL
    Assembly Full Name:  Microsoft.ReportViewer.DataVisualization, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.DataVisualization.DLL
    Assembly Full Name:  Microsoft.SqlServer.Types, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.SqlServer.Types.DLL
    Assembly Full Name:  Microsoft.Practices.Prism.Mvvm, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.Mvvm.DLL
    Assembly Full Name:  System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
    Assembly Full Name:  System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
    Assembly Full Name:  System.ObjectModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ObjectModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ObjectModel.dll
    Assembly Full Name:  Microsoft.Practices.Prism.SharedInterfaces, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.SharedInterfaces.DLL
    Assembly Full Name:  System.Threading.Tasks, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Threading.Tasks/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.Tasks.dll
    Assembly Full Name:  EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/EntityFramework.DLL
    Assembly Full Name:  log4net, Version=2.0.8.0, Culture=neutral, PublicKeyToken=669e0ddf0bb1aa2a
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/log4net.DLL
    Assembly Full Name:  SlimDX, Version=4.0.13.43, Culture=neutral, PublicKeyToken=b1b0c32fd1ffe4f9
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/SlimDX.DLL
    Assembly Full Name:  TrimbleDataApi, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleDataApi.DLL
    Assembly Full Name:  hics2320_cs141, Version=23.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
    Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hics2320_cs141.DLL
    Assembly Full Name:  System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
    Assembly Full Name:  System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
    Assembly Full Name:  System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activation/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activation.dll
    Assembly Full Name:  System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml.Hosting/v4.0_4.0.0.0__31bf3856ad364e35/System.Xaml.Hosting.dll
