Yes @Alan Sharp something like that but a little bit different, let me explain. In present TBC in profile view you can right click and choose which surfaces you want to show I would like to be able to have this option for other profiles (vertical alignments,3D linework and/or pipes and structures) and all other types of data. In that way you get a better overview of the different design elements and how they interact.
And I would also want be able to scroll through the different profiles to make the one you choose active, so if you choose alignment A that one gets active and if I then choose alignment B that one gets active and alignment A becomes passive.
And another question / #enhancementrequest is there a way to measure distance and slope in the profile view, I'll give you an example.
You have manhole A at an elevation of let's say +38.00, manhole B 20m further upstream at +38.04 and manhole C another 20m upstream at +39.00.
As you could calculate I have a very poor slope between manhole A and B (2 per mille). So what would the slope be from A to C? (You might want to suggest an alternative for your client)
And if the slope is between A and B what would the new elevation be at manhole B?
I would like to make a "helpline/temporary baseline" in the TBC profile view from A to C that will show length, slope length and the slope and from that baseline snap to manhole B to see the distance along the baseline (2D and 3D) and the elevation difference.
Can TBC make this scenario happen?
But for now I will try out your hidden gem @Alan Sharp and the beers are on me when you decide to come to Sweden, deal?
